I used a sketch circle as a temporary reference point to translate a body to the center of the workspace. After the translation, the body remains linked to the circle: moving the circle moves the body, and deleting the circle changes the body’s position or breaks the translation.
I also tried converting the circle to construction geometry, but the translation still depends on it.
I only needed the circle to position the body once. Hiding it isn’t a suitable solution because I want the native project to be clean, without leftover helper sketches, when I share it. Exporting the model as a STEP file gives me a clean file, but it doesn’t preserve the Shapr3D design history.
Is there a way to keep the body at its translated position and remove the temporary reference while preserving the rest of the editable design history? An option to detach or fix the translation after using the reference would make this workflow easier.
