[Known Issue] Windows 10 - Shapr3D Not Launching
We’re aware of an issue affecting some Windows 10 users where Shapr3D doesn’t start after a recent Windows update.
We’ve identified the root cause and are working with Microsoft on a permanent fix.
In the meantime, use the temporary workaround below to keep Shapr3D running until the permanent solution is available:
  1. Download the Shapr3D installer: Windows Installer here .
  2. Save the file in a location that’s easy to access.
  3. Double-click the downloaded file to run it.
  4. When prompted, choose Update or Reinstall.
  5. Once finished, open Shapr3D again.
the work around wont even work for me
Hi, to get assistance, please submit a support request using this link. Make sure to include your device’s hardware and software specifications. Thank you!
