Library and symbols panel
Library - Can easily import parts from a different shapr3d file. Symbols - Can easily sync/edit same part across files and drawings. Symbols are clones of the original.
Drag drop models/parts from a different file and edit an original part that is cloned.
It takes far longer to save and import a native file than opening a panel with all shaper3d projects and drag them out (it will be great to select layers too)
Library feature finally here! Thanks. Now I can split projects into parts, the app was slowing down at some point. Now symbols feature :smiley: please, were imported drawings syncs with the original.
