Link two sketch lines
Hi all,
Feeling a little dumb. I have two sketch lines I want to link, so that if I update the outer line, the inner line will follow it and keep the same distance between.
I’ve not used the many constraint tools before, I’m used to just drawing and extruding.
Can someone help?
What kind of update you talking about? Length? Position?
To keep distance between two lines you can add another line perpendicular to them and give it constant length.
Sorry, length.
If I alter the outer lines length, the inner line will follow it.
Like so?
Or like this?
Yes, that’s it :slight_smile:
Should I show you how I did that or it’s clear from the videos?
Being new, it’s not clear. Would you mind showing me?
same here :slight_smile:
Thanks so much that has really helped :slight_smile:
