Edge seems to somehow be “detached”, don’t know why or when this occurred.
Any advice on what’s going on here would be greatly appreciated, thanks
Hello Lucas1,
Yes have seen this as well. Try going on the inside and look outwards, see if the "splits"are still showing up.
I don’t find it to be a problem as it doesn’t surface on “print”.
Can you upload a couple more pics zoomed out so we can see the entire surface(s)?
In some cases, Replace Face can work.
In the past I had a similar error with the loft tool on the rounded edges.
The S3D guys told me, it was a tessellation error.
If it is really the error described previously, it does not cause a problem.
For sure, ask for a support ticket.
