Split an edge
I’ve got an edge that i want to do a chamfer for only a portion of it, but am not sure hw to split it.
02ADB55C-27AB-436A-A56B-5BAD28F47E7D
Ive attached a screenshot. The red loop is the edge I’m trying to split, and the blue arrow is roughly the portion where I want to keep it a straight edge, but every point up to there i want to have a chamfer.
Any suggestions?
Thanks!
Hi just divide your face with a quick sketch, and extrude the parts separately. Chamfer the edges you want then use the Union tool to merge the bodies.
I did a short video that might help (click on link!)
Hi!
Thank you for the video, it was very helpful! I found that if I tried to use the extrude tool on both faces, it won’t work. The only way I could get it to work was to follow your steps exactly, which was to pull-to-extrude one face, and then use the extrude tool on the other face.
Attempting to use the extrude tool on both faces (or pull-to-extrude on both faces) resulted in the pieces joining up again!
Thank you very much! :smile:
