Loft tool question
![IMG_ Hi everyone,
I have a question about the Loft tool in Shapr3D.
When I use Loft, I can no longer create a continuous loft around a closed circular path. I remember this was possible in previous versions of Shapr3D.
Has anyone else experienced the same issue? If so, is there a workaround or a way to fix it?
Thanks in advance!|666x500](upload://8CJh3dGPF3b9RCGXKXnMQum4hhY.jpeg)
Hi @duongtran, :smiley:
Have you tried to enable Periodic Loft under the Loft parameters? This creates a closed, continuous loft by connecting the last section profile back to the first.
Hi Cesar.
Thank you so much. i got it ! i really for get that
