Hi all,
I’m struggling to “Loft?” one sketch to another, they are slightly different sizes to produce a a slight trapezoid, smaller at the bottom than the top.
Top rectangle is 800 x 500 and bottom 792 x 486.
Am I doing something wrong, or is there not a method?
Thanks.
As far as I know, you cannot loft a sketch that is not entirely closed. Your ‘closed’ sketch has two internal openings. Not allowed.
Why don’t you do a normal extrude, then on one surface do a non-uniform scale. Here I start with a box of overall size of 800 x 500.
Thank you for the swift response. much appreciated.
