Does anyone know how to sketch a logarithmic/golden spiral in Shapr3D? I’ve checked the online documentation and searched the forums and cannot find anything. Thoughts?
-s.
Be well. Stay safe.
I would think you would need scripting capabilities for that.
Hi. I use the 90 degree approximation of the “golden spiral” in handrail making.
Most people drawing these use an approximation. But as @Oregonerd says, the genuine version would at least require a formula input of some kind.
There have been a few posts on the subject in the past, but mostly using a 180° approximation.
Let me know if you’re needing help with the 90° version.
Guidance for drawing the 90 degree approximation would be incredibly welcome. Thank you!
1̶.̶6̶1̶ ̶i̶s̶n̶’̶t̶ ̶p̶e̶r̶f̶e̶c̶t̶ ̶b̶u̶t̶ ̶c̶l̶o̶s̶e̶ ̶e̶n̶o̶u̶g̶h̶?̶ ̶Y̶o̶u̶ ̶w̶i̶l̶l̶ ̶n̶o̶t̶i̶c̶e̶ ̶s̶o̶m̶e̶ ̶a̶n̶n̶o̶m̶o̶l̶i̶e̶s̶
Try 1.618 as your multiplier.
Thank you for the link and guidance! You all are the best!
-s
I think my solution is closer to the Fibonacci, less Golden ratio.
Helping you was a fun rabbit hole for me!
This was quite fun for me as well! Thank you so very much!
