Make pipes fit into another pipe?
Hi, i found out how to sweep and make pipes, inner radius is 3mm, how can i make these two pipes fit into eachother? i want a 3mm overlapping
17
I would love to see a video in how to do this :slight_smile:
I am trying to make a new drain pipe to my caravan that has to be custom made :wink:
Hi Freddy,
If you have sized the ID and OD of the two pipes correctly, including tolerance, it is a simple matter of moving one into the other with the Transform - Move/Rotate/Scale or Translate tool. There are lots of examples in the Tutorial videos on this…
