I drew about 8 concentric circles. I selected them all and used the Concentric constraint.
Later I cut arcs in these circles and added radial and other lines to them.
When I zoom in to a resolution of 0.01 mm, I find that the centres of these arcs is no longer concentric. Is there anyway I can make make these arcs concentric again without having to delete the  radial / other lines that connect these arcs?
The image of the centres in the zoomed figure is pasted below:
An image of the arcs and connecting lines is below:
Thanks,
Ajit
              Did you try using the Concentric constraint? You have to select only two points for it to be available, I believe. Just keep selecting pairs of points until everything is concentric.
              At times drawing in Shapr3d is incredibly clumsy. ‘Arc from centre’ is a glaring omission, yes you can two points and then locate the centre but that is not always comfortable. Please put the option in there. Driven dimensions are important too, I want to set a length that is the sum of two existing dimensions. There are lots of missing features like this that make sketching very slow and unnecessarily complicated.
