Mirror to all chamfer edges
I’m getting back into using Shapr3D and I’m running into a problem that I’m trying to solve, I have a box which is chamfered on all top sides the same size as the height of the box.
Then I have two rectangles drawn on one of the chamfered edges, how can I mirror this to all chamfered edges without needing to manually do it for each side?
Summary
This text will be hidden
Mirroring doesn’t work in 3d, only on the same plane, use circular pattern tool.
Mirroring works in 3D without any problems.
The question is why TC needs to mirror the sketch in this case…
I would recommend to use pattern as @SCALEMODEL suggest but on a result of extrusion of the sketch
This is good to know thanks!
