I am running Shapr3d on a windows back-flip style notebook. Depending on whether the app is running in a window, or full screen, or full screen rotated I get more or less menu items. Specifically, the “Project” option will not show at the bottom of the list.
Menu when windowed:
Menu when full screen adds ‘Project’ .
And when running in ‘tablet mode’ (ie: rotated on end), the menu also shows ‘Color’.
Is this a bug, or is there a setting that I haven’t found?
Thanks!
Hi!
It’s a bug: when the window size is not enough vertically, we simply cull the items from the menu. That’s obviously not how it should work and it’s an annoying problem. We are working on a fix and it’s due to be released in a few weeks.
In the meantime, one possible workaround is relying on the selection-based interface: just select the items you’d like to interact with and the list of actions will be filtered accordingly. In most cases that would also mean they’ll fit into the screen.
Peter
