When I’m in the default view (Double Click Cube) my objects are very dim. If I zoom in then they get much brighter. See the two examples below.
Is there a solution to this problem?
I think that’s because you assigned metallic materials to your objects. Depending what angle the reflect, they can be very dark or very bright.
I’d advise to use flat materials or just a simple color change while you’re modeling, and only assign materials once you’re ready to visualize. Also using bright pastel colours helps a lot with visibility while you’re modeling.
I think lighting is fixed and doesn’t follow point of view in modeling mode. Bottom is always dark for some reason.
Wow, that made a big difference !
Thanks!
Rick
