I’m working on a project where I have to place light sources onto a metal frame with different angles, not square, 90° or 45°.
Right now I have to place every body with the align tool. It will snap to the center of the metal bar and from there I have to move it to the desired position. If I want to change the position even slightly I need to start all over again with the align tool. Because the Move tool is then again oriented in the direction of the 3 axis.
I would like to have the possibility to select a body or a folder and move it along an edge straight or curved in relation to the distance and orientation of that body. Idealy combined with the pattern tool.
It will speed up my workflow significantly, if I work on constructions which are not in a 90° angle. Or working on organic shapes.
