Move object centre vs object origin
Hi there,
I am struggling with moving objects f.e. moving the centre of circle in 3d to the Endpont of a line in order to sweep it afterwords.
I find myself moving the origin, but not the circle object. When I first move the origin and then the circle, there is no feedback if the circle centre had hit the end of the line point - it usually does not. What am I doing wrong?
I appreciate your advise
F
… this occured while trying to model the mesh field auf fence, squares rotated 45 degrees, wires are 3mm thick an an one above the other. Next challenge would be how to create a woven mesh…
