I use Move/ Rotate very often to precisely position or rotate a body on the grid but in some cases the point of the gizmo does not move the object, only the arrows are operational.
Is it misuse on my part?
Not sure what you mean by “point of the gizmo” but the center of the gizmo is not intended to make the object move; it’s meant as a reference for center of rotation.
Origin point I think. Used to be we could move stuff by the origin point. Haven’t tried it in a long time.
Hello,
I’m sure I saw this in a tutorial.
Click on Origin Point of the gizmo and drop the object in (0,0) for example.
Thank you.
The origin point doesn’t move the object now it seems. However, there are squares which appear that allow you to freely drag the object in the corresponding plane.
