@Bizzaro
Select the whole Body within Items.
Adjust the view of the Body using the usual Finger Control movements.
This should reveal that the Pivot Point of the Move Tool is at the Centre:
I think you misunderstand what I need. If the center point of the move tool has… well… moved… how do you get it BACK to the center? There seems to be no way I can find to find the center point of the object again.
@Bizzaro
This will not function when the Body is in a square on view, i.e., the Grid shows on a Face of the Body.
Use a Finger to move the Body into a 3D view
Select that Body within Items, leave the Body Selected, then use
Transform > Move/Rotate
If that does not give the result you need please attach a Video of what is happening.
Here is a more clear video for you.
Thanks for the Video.
This is the Sketch Centre:
To Move the Sketch Select/Highlight it within Items [see lefthand Column] the use Transform > Move/Rotate. With Snaps switched on you should be able to position it accurately both horizontally and vertically.
I moved the Body to be centred on the junction of the Axis, this is the Body Centre:
In this case it is horizontally centred on the Z Axis and vertically on the Base [underside] of the ‘Tray’.
This is verification of the Centre from the Plan and Elevations:
Note: There will be only one Body within Items if you have used Tools > Union
It can be useful to centre you Designs around the Axis Junctions, but that is down to personal preference.
In this the Body Centrer is centred on the Axis Junction:
I would sketch additional line for mid point reference or two lines for interesting point
And how do I find the midpoint to add that to a body exactly you suggest if I don’t know where it is?
@Bizzaro
May I suggest that you Sketch A Cube centred on the Axis Junction
Sketch > Rectangle > from centre > position the Pencil on the Axis Junction
Pull up the Rectangle to form a cube.
This will have formed a Body within Items
In Items select/highlight Body 01
The Cube will be Selected complete with the Move Feature
Use only your Finger placed just below the Cube move it gently and observe that the Centre does remain in position relative to the Cube.
If you touch the Move Feature you will be able to move it but it will not remain in the centre of the Cube:
The Centre is found automatically, you do not need to ‘play’ with anything.
