Moving an object
I’m having problem when moving the object like the circle. When I drag the centerpoint of the circle to move it, it also changes the diameter. Is there a tool command to move the highlighted object only not affecting the diameter of the object?
Lock the circle’s radius
Hi thank you for your reply, this is what happen when I lock the radius2BA5F7EE-6178-4E83-880E-52306063095C
You’re not locking the radius, that’s the center point.
Touch the circle with the pencil and specify the radius, and there you can lock/unlock
//RBF18CF41-1F8F-45B9-89B9-215AAE4F11BC
