Why are my circles connected?
I have a circle with 5” radius on the xy plane.
I need to draw another circle in its center which also happens to be the xy center. So, sketch, circle, click and drag and enter my radius.
The issue though is that my new circle becomes part of the original circle so now when I try to move it up to where I want the bolt hold it drags both circles. I don’t know why this happens all the time and I don’t know how you undo this unwanted behavior.
Thanks,
Glenn
Select the circle you want to move and then tap Disconnect on the right side of the screen. You should now be able to move only that circle.
I think the software assumes that if you make circles centered at the same point, they should stay concentric.
