Hello,
@welshsteve solution is great as it allows to change the colors at will.
The only limitation is you can’t union the bodies to create a single body mug, as it would kill the stripes.
If you want a single body mug, you have to create an edge one way or the other, for instance as in the video.
Alternatively, creating even a slight edge would allow the segments to be unioned and still be selectable.
Or, one could project the stripes onto a single body cup allowing each stripe to be coloured individually.
As I stated, there are numerous ways but unfortunately they’re all tedious ![]()
Wow ! Thank you ![]()
The cup at the lower part is angled, bottom is smaller in diameter than middle of the cup. Therefore I was fighting with projecting the pattern plus I was adding the pattern to the finished cup . I created separate body and “injected” in the cup. The black wide strip is separate part as this is a holder made of rubber to hold the hot cup.
Looking forward to seeing the finished product ![]()
Cool !
sön 10 juli 2022 kl. 15:06 skrev martin via Shapr3D forums <notifications@shapr3d.discoursemail.com>:
mug.shapr (1.1 MB)
