Hi, i have a small issue. I’m trying to project something on a cylinder, but it comes out stretched out as you see in the pic. How do I fix this?
That’s exactly how projection works and exactly what this word means.
I assume what you’re looking for is wrapping, not projection. But S3D doesn’t support it.
So what would be a good way to create a pattern? Just make the shape and use circular pattern?
It depends on the task and the pattern you want to create. I’d need more info to give a more precise explanation.
I’ll play around with it. I’m looking to do hexagon shape or an angled line
