When I try doing a boolean Subtract, I do not get a “Done” button.
I do get a “Done” button with Intersect and Union.
J
J
Hello - please check if you haven’t already subtracted the part before (move it away and back). If that is the case, Done button is not shown as there is no common part of the bodies.
It might be the case that you have kept the Removed Bodies (default setting at the moment). You don’t see the subtracted result because it is covered by the kept Removed Bodies
Before Subtract
During Subtract (Note the Keep Originals option set to Removed Bodies)
After Subtract (Note the kept Removed body and the created edges compared to the original state)
After moved
Can you please upload the workspace (in .shapr format) or send it to daniel@shapr3d.com and I’ll take a look. From the picture it seems like there is nothing to subtract (so no Done button), as there is no common part.
email sent
Fantastic!
I did my extrude wrong when making those two objects.
Thank you!
Jason
