Yepher
February 27, 2021, 3:11pm
1
I notice sometimes there is no opacity control when I import into Shapr3D. What is the trick to get that to show up on import? It works sometimes on iPad but I don’t recall it ever working on the Mac. How can you adjust opacity after import?
I use that feature quite a bit
I am running
iPad: v3.59.0 (837) #cfa8edb9
Mac: Version 3.60.1 (930)
Mac Example
iPad Example
Laci_K
February 27, 2021, 3:14pm
2
Thanks, we will investigate.
You can always adjust opacity from the items bar even on mac, as a workaround.
Yepher
February 27, 2021, 3:16pm
3
Awesome… If it is that easy I don’t even care about the import time adjustment.
Laci_K
February 27, 2021, 3:17pm
4
It should work, so we will check it anyway
Yepher
February 27, 2021, 3:21pm
5
I am not sure if it is related but interestingly the image came in upside down on the iPad which I don’t recall seeing that happen before.
Laci_K
March 1, 2021, 3:47pm
6
Fix for the opacity will come in the next release.
