Object export does not create an object tree.
Exporting a design with different objects (parts) for import In blender3d results in all the parts being joined as one.
This makes it impossible to add materials to the different parts of the design.
FreeCad does export the objects separately and blender3d can import them as an object tree. Unfortunately the quality of the mesh conversion from solid object to mesh in FreeCad is full of errors.
I ca export my design as an object for blender3d, where all the parts of the object are separate objects (adhering to my folder structure in Shapr3d) which I can modify separately in blelder3d (add materials etc)
I have modelled a bicycle in shape3d that is customisable (colours, components and cabels)
Photorealistic marketing material needs to be produced in all the different variations (50 different photo scenarios).
I can’t do it using shapr3D.
You can separate them in Blender. Just use the Separate function and use the “By Loose Parts” option.
Hi @TheBum Alen,
Yup, this works.
Also at import, selecting “split by group” also separates the parts.
This is definitely a work around.
However, I have several hundred objects that I organised nicely in Shapr3d which all get lost importing into blender.
Interestingly FreeCAD describes the file their export file inn such a way that objects can be split during import into blender3d and groups them correctly.
