Offset Arrow Bug?
Click on Offset arrow pops open calculator.
Nothing, miss click on the arrow should not open the calculator only happens with the offset tool.
When the tool is already active, clicking the arrow enables the input field, also known as the calculator. This behavior is also present in other tools like Extrude. However, if you activate the tool and drag the arrow instead, the calculator will not appear.
Actually its only on the offset in sketch mode, I noticed this behavior using the trackpad.
Clicking on the arrow on other tool hides dimensions.
I started clicking on the offset arrow because I got used to a certain trackpad behavior on mac that made you click to release drag and hold.
I can see that on the first video, you have the “offset edge” tool activated. The 2nd video does not have this tool activated. Activating the offset edge tool and clicking on the arrow will activate the input field for the dimension.
