Does anyone know how to tackle this problem?
Since the distance between the holes is too small, the arrows overlap.
In other CAD software, we can solve this by changing the arrows to dots or slashes, and by moving the dimension number away while keeping a leader line connecting it. However, I couldn’t find a similar option in Shapr3D.
If anyone knows a workaround, I’d appreciate your insight.
You can’t change the line type, but you can move numbers away and arrange them as you like.
You might not like this workaround, but here it is.
Don’t put dimensions, and since you are familiar another CAD program, possibly like Autocad do the dimensions in Autocad.
Increase your paper size so the text scales.
thank you for your response.
Yeah that are some of the options that I am using right now.
I just hope there are other way that can do it more professionally.
Unfortunately I dont think we have that option right now
thank you for your insight.
