Paired live AR preview between iPad and iPhone
It would be useful to use an iPhone as a persistent AR viewport while editing the same project on an iPad. The iPhone would display the model in its real-world position, while the iPad remains the device used to edit it.
Example workflow:
  1. Open a project on the iPad and start a live AR preview on a nearby iPhone.
  2. Place the model in the intended real-world location and set its scale.
  3. Keep the iPhone’s AR view anchored while making changes on the iPad.
  4. Send those changes to the iPhone in real time, preserving the model’s position, orientation, and scale.
This could be useful for several workflows:
  • Design and fit checks: Review the size, clearance, and proportions of furniture, fixtures, enclosures, or other products in their intended location, and adjust the model while seeing the result in AR.
  • Client reviews: Show a client a full-scale AR model on the iPhone, make requested changes on the iPad, and let them see each revision in place.
  • Product presentations and advertising: Film the AR model in a real setting, then switch between configurations, materials, colors, or assembled and exploded states from the iPad while keeping the iPhone’s view and framing in place.
  • Design reviews and collaboration: Compare design options in context without repeatedly exporting the model, reopening AR, and placing it again.
A view-only mode on the iPhone would be enough; all editing could remain on the iPad. Controls to pause the preview, reset the anchor, or reposition the model would also be useful.
What outcomes do you expect from this feature?
I would like to use my iPhone as a live AR preview while editing the same project on my iPad.
For example, I’m currently creating a promotional video of a rotating display platform I designed in Shapr3D. I want to show its exploded view in AR and then gradually bring all the components together into a fully assembled product.
With live synchronization, I could move the components on my iPad while recording the AR scene on my iPhone, without interrupting the recording or changing the camera position.
Currently, every time I change the assembly on my iPad, I have to wait for the project to sync, reopen it on my iPhone, and place the model in AR again.
This makes it difficult to maintain exactly the same position, orientation, and scale between different assembly stages.
As a workaround, I have to record each stage separately and try to align everything during video editing.
Live AR synchronization would make this process much easier and allow smooth, continuous demonstrations of design changes and assembly sequences.
