When trying to model interacting parts.
Most CAD programs can allow you to set what shapr calls alignment features but lock them in and have the parts interact in a certain way. This is especially helpful for modeling things as simple as a swing joint hinge to make sure you get your lengths correct to allow for the proper movement, start, and end position.
Currently you have set alignment. There is no ability to move objects in relation to one another so you have to re-position every part individually and have no full scope of movement in relation to other parts. This makes it very difficult to design and engineer for real world applications beyond a singular pivot point of a single object or sub-assembly.
Even modeling simple joints/hinges that aren’t constrained by a singular pivot that can be viewed. Where multiple parts move in relation to one another, ie. a simple 4 link system, or modern door hinges that can swing out as well as around.
Yes, this adds hours into moving individual parts in relation to one another, calculating angles, distances, then notating all of them separately, in order, and having to reference them to move them back step by step. If a part is modified, ie. a hinge point, repeat the process again and again. And still can’t see possible interference by doing this from a start/stop position.
