Pattern Along Path / Follow Curve — Is it supported in Shapr3D?
Hi everyone,
I’m currently using Shapr3D on iPad (and also checked on Mac) and I’m trying to find a feature similar to a “Follow Path / Pattern Along Path” (i.e., duplicating a body or feature along a curve/spline, with the instances rotating/orienting tangentially to the path).
I’ve searched through the Pattern tools and the menus pretty thoroughly and I’m almost certain this isn’t available (I only see linear and circular patterns), but I wanted to ask here to confirm, maybe I’m missing something or there’s a recommended workflow/workaround..
I really like the app and the UI/UX is excellent. I’m on the trial right now and I’d happily buy the full version because the workflow feels great. However, if there’s no “pattern along path / follow curve” option, that’s unfortunately a deal-breaker for my use case and I’ll have to keep looking for another solution.
Does Shapr3D support this feature today (on iPad or Mac)? If not, is it on the roadmap, or is there a reliable workaround you’d recommend?
No.
Probably next year.
Pattern Along a Path next year! Sweet! I much prefer this over threads.
