Love all the improvements you guys are making. I have one tiny itty bitty feature request that would help my workflow (and I’m sure for many others). Maybe someone could work thru their lunch hour and do this. When creating a construction plane could you make the last parameter selected be the default instead of offset? I often use midplane and it would one less click to not have to select it each time. Thanks!!
If you select two planar surfaces, the tools sidebar is adaptive and will show “add plane, mid plane” button automatically.
You do not need to go to add plane and select mid plane using this method.
If it’s not showing up, make sure you’re using the latest Shapr3D update. This feature “accidentally disappeared” briefly and was fixed.
