Plans for 3d PDF Export?
Are there any plans for 3d PDF Export?
We have to use this format for exchanging models.
Thanks in advance, Florian
What does a „3d pdf“ mean, actually?
Something like this export function: Saving 3D Models as 3D PDF Files - 2022 - SOLIDWORKS Inspection Help
There‘s No way to do that yet. But, I suspect this type of export would only be used in a certain small part of Shapr3d users, so probably, this isn’t going to be developed for a time. You should try to find a workaround.
Good Luck!
I thought so… The workaround is sharing via the Shapr3D link. Thanks for clearifing.
Perhaps this can work for you
