Exporting from Shapr3D is quite a number of clicks, especially if you make mistakes like myself. I mostly export to jump into my Slicer for 3D Printing.
I currently launch the Export Dialog by using the keyboard shortcut. I have already added the 3MF file format as a favorite to keep it at the top, but I noticed that the launches without a selection
A very simple feature (I suppose its just a couple lines of code) would be to just select the first item in the list by default or restore the previous selection.
I set Favorit Format (starred) to STL and then by some third part (for example, Keyboard Maestro) assign a shortcut to Export to > Quick Export to Favorite Formats (to do several fast tests when merging complex items).
So, just one single com-n (or even a single n) and the export ‘Save as’ open.
Would be super cool if there was a shortcut or this option was available via the search command palette.
The quick export option is actually just as … quick… as the normal one as you need to go to File → Export to → Quick export instead of just pressing cmd+shift+e and clicking once.
I found out I can just do cmd+shift+e → tab → tab → enter, which feels quite fast..
I proposed this as I don’t see the benefit of the empty screen in the dialog, I think even a first-time user would understand the list and selection. And as a repeat user you can then just do cmd+shift+e → enter
What is annoying for me is if I have multiple file formats in my favorites, it won’t ask me which one I want but export to all of them in a compressed folder. Very unnecessary in my opinion.
I thought I would use it to create “organic” shapes, land, materials, etc…
For example, I was thinking of Extrude, a loop and a random() for the extrusion height but I didn’t have time to code it and do tests.
