One of the best ever 3D design , I have problem with transform the shape I can’t move or rotate when selected the shape !!
Can you share a bit more detail? Do you select the transform tool, select a shape, and you can not rotate it with the rotation arrows?
Yes mr istvan I can’t move or rotate the shape I try also with pivot point also I ant rotate or move with arrows
Is it possible that you have screen scaling turned on?
system settings->display&brightness->view->zoomed?
Thank mr istvan i do it , now I can rotate move and scale with arrows, what was relation between zoomed screen and transform in shapr3d
Yes, sorry, that’s a known bug, it will be fixed in the next release. Until then it can be worked around like that.
