Project fail
Hello I’m trying to project but I got project fail!
I try on top on right half project is sketch
Hi, it’s only possible to project a sketch on planar bodies. Select the “Edges” project option instead while projecting the sketch and that should work :slight_smile:
Hello, I try on sketch and on edges same problem project fail
Hi, thanks for your response. Please send us the design file via support@shapr3d.com. We will further investigate the issue from here and then get back to you.
Thanks bro
