I just want that drawing to extend down into the top of the part about .01 while following the precise contour of the top of the part. I’m trying these steps (see below). I THINK I’m get through step 2 successfully but then can’t get any further. There doesn’t seem to be a way to select the entire face of my my object. I can select only one little piece or “facet” of it.
Step
Action
Description
1. Create Your Sketch
Create a construction plane above your object and draw the 2D sketch that defines the boundaries of your desired feature.
This is exactly as you described in your question.
2. Extrude the Sketch as a New Body
Use Tools > Add > Extrude on your sketch. Extrude it downwards so that it completely passes through the top surface of your irregular object. Crucially, ensure this is created as a New Body, not joined to the existing one.
You now have two separate bodies: your original object and a new “tool” body that represents the volume you want to work with.
3. Select the Bottom Face (or is it the top face?)
Tap to select the flat, bottom face of the new “tool” body you just created.
This is the face you are going to replace.
4. Use the Replace Face Tool
Go to Tools > Replace Face.
This tool is designed to extend or trim a body by replacing one of its faces with another surface.
5. Select the Target Surface
The tool will prompt you to select the target face. Tap on the irregular top surface of your original object.
Shapr3D will now calculate the intersection and trim the bottom of your “tool” body so it perfectly matches the contours of the irregular surface.
6. Perform the Final Operation
You now have a “tool” body that is perfectly shaped for your operation. Use Tools > Subtract to cut this tool body from your original object. If you wanted to add a feature instead, you would use Tools > Union.
This will leave a pocket (or an embossed feature) where the bottom of the pocket has the exact same curvature as the original surface.
I’m stuck on this part:
