Projection on Cube
Question: There is no problem to project on sphere, but how to project on cube or cuboid, on all faces?
HI,
Try to play with Wrap & Emboss…
Thank you very much! It works! And with a little adjustment, the lines of all faces seem to be connected now.
Great!! As you can see on my image, I added a guide per face to modify the Center point. I can go up or down to adjust the positioning and the connection with the top.
And don’t forget to rotate for each side. I created icons (circle, square, triangle…) to find my way around.
Thank you so much for the tips! :folded_hands::folded_hands::folded_hands:
