Radius tool
New here and wondered, is there a radius tool to simply add a radius to corners?
No. Draw a radius and connect lines or draw draw your corner then radius or circle and use the trim tool. Clunky but no radius tool for line drawing.
Thanks. I had been doing that but hoped I’d missed the radius function.
Thanks for the reply
That said, if you intend to extrude a solid, you can always use the chamfer/fillet tool after extruding. It’s super easy to use: it’s selected automatically whenever you select an edge.
I for 1 would prefer both methods were available.
