.Rounded Rectangles
Is there any easy way to draw a rounded rectangle? I find the arc tool less than useful for pretty much everything, and trimming multiple arcs from multiple circles is tedious-
My preferred method is to draw the rectangle, then extrude it. I then filet the edges to my liking. I create a parallel plane just above it, then project the rounded rectangle surface onto the new plane. Then I delete the original sketch and body.
Thank You- I hadn’t thought of that- it still seems like quite a laborious workaround though
Perhaps, but I don’t use similar radii that often. So this method allows me to have each corner a different radius, for both filets and chamfers. I find the parallel plane method very helpful, far beyond what I’ve described here. Enjoy!
