Recreating Table Design in 3d
Hi… I saw a beautiful table build on Instagram here:
I have pretty much figured out how to design everything. But the legs. They become smaller going down to the floor. They have three sides rounded differently and the inner side has a special cut.
Any help would be much appreciated.
Best
Ben
Sali @BenSiato
One idea is to ask the manufacturer how he did it.
Most people answer very friendly, in my experience.
Ps: it’s best if you realize your own ideas.
Mit freundlichen Grüssen
Andreas Desiderius Haudenschild
Here you have another book tip for wood connections:
To me it looks like the leg is tapered on the inner two sides. I used 2.5° taper. The outside corner has a nice radius. Can’t see the special cut from the video.
Thanks Andreas. I’m actually using the design to practice Shapr3D :slight_smile: Will have a look and the book. Seems like one of those must-haves for the bookshelf in the woodworking shop. :+1:
@BenSiato
Please, for me personally the book is still interesting
Sali @BenSiato @TigerMike
I tried it once
PS: Thanks Ben now I have loft function endest which is useful for me.
I have another option.
There is also the possibility to work with axes and with the subtract tool.
I added a few pictures for this.
Sali @TigerMike @BenSiato
Here I have another version with construction level And share:
Here is the loft version.
From the TOP
Sali @SCALEMODEL @BenSiato
Another version
I refined it.
Here what the sketch looks like top and bottom you would just need to loft it. If you use constraints it will be easier to shape it correctly and adjust it by eye to compare with the photo by inputing dimensions.
Since I made the legs anyways I thought just finish it. I also liked the brown version.
Thank you guys. I ultimately went with Loft & Extrude the top part. Looks pretty much like it should. Now I’ll have to catch up with @SCALEMODEL . Nice Work!
