Good morning.
I am struggeling to understand a feature when projecting.
In this photo the circles to make the holes was projected from the bottom face onto the top face. I tried chaning the diamter of the holes from 3,2 to 4 but all the measuremenst work in reverse, If I click on the inside and chose 4mm the hole actually becomes smaller.
What am I doing wrong?
In this picture the diamater for the first hole is 4mm. When clicking on the projected face that was extruded it looks like the programs is measuring the distance between 2 faces instead of the diamter of the cylinder
In this picture I used offset face instead of extrude and with this method the program measure the diamter of the inside face of the cylinder but it still does not measure the diamter of the cylinder on the side where the pojection was made.
