Rotating an ARC
Hi Happy Sunday! Except for those places where it is Monday… In which case, happy Monday!
I need to be able to rotate the arc below, so that the end points are 90 degrees from the center. How do I do that? I have tried many ways to try and draw and arc that will mimic a corner radius on a sketch. But have failed… ideas? I get that they are 90 from the center already, but I want 90 degrees horizontally, or vertically…
Hi!
If you select the arc, and close the sketch menu, you will have access to Move/Rotate tool by default, which can be used for this. In some cases, Translate tool from the More option might also be helpful/work better than simply rotating.
Is this what you are trying to achieve. I assume you wanted to rotate from the center of the arc. If you meant the XYZ center, the same approach applies.
-Mike
Probably!! Let me go try it…
Another way could be to connect the center point and one end point of the arc with a line, then make the line horizontal/vertical
