Is it possible to align the corners of a rectangle to a curve? See screenshot for what I mean.
Hi, It is possible, but please do not forget that the sides of the Center and Diagonal rectangles are horizontal/vertical by default. To make a rectangle that is rotated from the first moment of creation, please use the Three Points rectangle
Here’s another way. Draw a radius line to a point on the circle. From there, draw a line tangent and perpendicular to the radius line. Measure the angle between the tangent line and one line on your rectangle. Use Move-Rotate to rotate the rectangle to that specific angle and then move towards the circle.
-Mike
