Hi, I’m new to Shapr3D, and loving it, don’t own it yet but probably will when I can use it fully.
I’ve checked this question on the forums already, didn’t find a satisfactory solution, had a play around, then found a solution using the offset tool, which provides radius centres automatically, circles can be drawn, moved to centres ,radius specified to match the offset Dimension, then the waste lines can be trimmed off…voila!
Hopefully I can successfully upload a couple of screen shots…
