Rounded Rectangles
in sketches can we please finally have rounded rectangles?
tired of using the recommended methods. They are too many steps. I use slots a lot, and I understand making a slot feature similar to Fusion360 is asking a lot, but even allowing a second click on the final edge to create the fillet or chamfer would go a LONG way.
You don’t even have to make it editable, One shot. If we get it wrong, then we delete and do again.
or at least have a simple method to select all extruded edges which can then be rounded all at once. It’s often annoying to go around an object to select all!
You can use the select tool , select the edges…
Thanks, I hadn’t hadn’t realised that select could be used to just select all the edges!
If you want reasons for why Rounded Rectangles should be a native structure, I’m reminded of this article dating back to the founding of the Macintosh.
The Original Macintosh Folklore: Round Rects Are Everywhere!
