I’ve been stuck with days for two days now. Trying to get fillet all these edges and want to make it look like a continuous fillet all around, but understandably, the slanted edges would require a bigger radius to appear to match the other ones.
Usually my method for more intricate fillets is sketching, sweeping and subtracting a profile along the edges, but of course, because of the slanted surface, that doesn’t really work either.
Any ideas on how to tackle this?
Fillet the edges individually to match.
I’m sorry, I think my attempt to isolate the issue ended up oversimplifying it. This is the actual usecase. One of the issues is that the shape is not symmetrical, meaning the fillet would have to progressively scale somehow.
I’ve tried all kinds of things, such as cutting away the slanted part and then using loft to create a gradual transition, but nothing has worked so far. I caaan get something roughly light, but the edge loops end up being really ugly and create weird shading.
If this kind of result is ok than try to turn off “Include tangent edges” option in some fillets.
That looks very clean, but I don’t quite get how you achieved it. I can fillet one edge at the time but still can’t seem to get it right. Did you fillet in any particular order? And did you trial-and-error the radius values or calculated them somehow?
Just eyeballed.
Because it was merely a trial, I did not focus too closely on precision.
After a few adjustments, I achieved that outcome.
That looks really good!
However, if you’ve still got some energy left, fillets 3 and 4 in your screenshots should be the same radius. It’s the edges between them than need a higher radius to match.
and if I just try to fillet the edge in the middle (the slanted one), I get an error message that says adjoining edge not blended. It only works if “include tangent edges” is checked.
I really appreciate your time!
That’s where the problem lies. They can’t have the same radius because Shapr3D doesn’t support variable-radius fillets. As a result, the central fillet has a constant radius along its entire length, but it meets the top face at different angles. As a result, different radii are needed to make the fillets look visually consistent.
I’ve tried to filletting the upper edge and it seems a little better to me, right?
Yeah, I understand the issue. But they need to be the same as they connect to other geometry that is also filleted. If they’re not the same, the difference would be visible in other places.
Sorry I explained the problem poorly originally.
I’m pretty much stuck with having to keep fillets 3 and 4 the same radius, but will have to figure out another way to fillet the slanted edges.
Hi, thanks for the input! The upper edge (the diagonal one) needs to only have a very small fillet, it needs to be sharp. So it complicates things.
