Shapr3d For Sketchup
Eu sou usuário do Sketchup, porém estou gostando muito de usar o Shapr3D, ainda estou apenas me familiarizando com a versão gratuita, não migrei para a versão paga.
Sou arquiteto e por isso projeto muito com Sketchup.
Minha dúvida é se existe chances de ter uma forma mais limpa de exportar do Shapr3D para o Sketchup? Além do formato STL já existente?
Obrigado a todos!
From what I’ve been able to gather, Sketchup works with polygon meshes whereas Shapr3D works with BRep bodies. They’re two completely different representations. STL is probably about as good as you’re going to get, which means you won’t be able to edit your Sketchup objects in Shapr3D unless you can find a conversion app that will create BRep from STL.
Fusion 360 can do the conversion for simple meshes. The problem I’ve had is some STLs aren’t “proper”, which can cause weirdness in the BRep equivalent.
