Shapr3D on my iMac crashes when open it
The program on my iMAC crashes when I open it.
See below the log:
Translated Report (Full Report Below)
Process: Shapr3D [53544]
Path: /Applications/Shapr3D.app/Contents/MacOS/Shapr3D
Identifier: com.shapr3d.shapr
Version: 5.980.0 (9712)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-11-01 22:39:51.1420 +0100
OS Version: macOS 13.7.6 (22H625)
Report Version: 12
Anonymous UUID: 5ABDD25D-0937-16DF-7D1D-86879A50D84A
Sleep/Wake UUID: CCF4D5B8-EAAA-409A-BE72-20F591D054FB
Time Awake Since Boot: 280000 seconds
Time Since Wake: 1207 seconds
System Integrity Protection: enabled
Crashed Thread: 37 FEngine::loop
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Application Specific Information:
abort() called
Model: iMac15,1, BootROM 478.0.0.0.0, 4 processors, Quad-Core Intel Core i5, 3,5 GHz, 24 GB, SMC 2.22f16
Graphics: AMD Radeon R9 M290X, AMD Radeon R9 M290X, PCIe, 2 GB
Display: iMac, Retina 5K (5120 x 2880), Main, MirrorOff, Online
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343531533641465238412D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343531533641465238412D50422020
Memory Module: BANK 0/DIMM1, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E433136465044
Memory Module: BANK 1/DIMM1, 8 GB, DDR3, 1600 MHz, 0x859B, 0x435438473353313630424D2E433136465044
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x142), Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1772.1)
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: APPLE SSD SD0128F, 121,33 GB
Serial ATA Device: Samsung SSD 870 QVO 2TB, 2 TB
USB Device: USB30Bus
USB Device: USB3.0 Hub
USB Device: USB3.0 Card Reader
USB Device: Elements 1042
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: FaceTime HD Camera (Built-in)
USB Device: USB2.0 Hub
USB Device: USB Receiver
Thunderbolt Bus: iMac, Apple Inc., 26.1
Hello, please open a support ticket here with the following information:
Thanks!
