Just trying to import what appears to be a simple Illustrator file, but after DXF conversion (web service) it’s got stray points all over the place to the point that I can’t scale it down to the size I need to work with (Shapr3D reports constraints issues).
Definitely better, but I’m trying to bring this down to fit inside a 4.5cm circle and I still can’t scale it all the way down without the Transform failed message. But I get a lot closer now…
Hi, if possible, please export in AutoCAD version R14 from Illustrator and select the Outline Text option. The attached file was exported this way, it has fewer control points.
I don’t think he has illustrator. I retried it in Corel using R14 both ILKI2.zip (12.3 KB)
text and curves. I did get rid of the outlined box which shouldn’t make a difference to his work.
