On Windows 11, when I export with the option “Save each 1st level item separately” the .ZIP file that’s created is not able to be opened. Windows states they’re ‘invalid’ I’m in the process of backing up designs and it’s messed up quite a few files now. Is there a fix for this?
Hey @someguywhomakesthing,
Thanks for reporting it, we’ll investigate the issue. For “workaround”, avoid to use Save each 1st level item separately option in case of single bodies. Use this option if you want to save several root level items separately.
